Re: Farmall 300 Belt Pulley
Posted by Janicholson on July 07, 2010 at 20:13:59 from (67.72.98.45):
In Reply to: Farmall 300 Belt Pulley posted by Steve Schrader on July 07, 2010 at 17:42:46:
If you keep the tractor, and do not even consider using the drive for flat belt attachments (or anything) leave it off. Make a plate to cover the hole out of 16 gauge steel. Make a template by using tag board and a ball peen hammer to tap around the drive attachment surface, including the holes, then cut it out for a perfect copy. Then make a gasket the same way. Save the drive for eventual sale with the tractor, or a discovered use. Jim
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
