Re: H and M clutch
Posted by mkirsch on July 08, 2010 at 05:16:19 from (64.80.108.55):
In Reply to: H and M clutch posted by GaryinKS on July 07, 2010 at 17:40:37:
You can change clutch and pressure plate on Hs or Super Hs.
You can change clutch and pressure plate on early Ms.
You can change clutch only on later Ms and Super Ms.
You can NOT change clutch or pressure plate on MTAs, or anything newer, without a split. The IPTO and TA are in the way.
The flywheel requires a split of the tractor no matter what.
