Re: Farmall-A Fan Assembly - 1 vs 2?
Posted by gene bender on July 08, 2010 at 11:51:20 from (207.177.56.232):
In Reply to: Farmall-A Fan Assembly - 1 vs 2? posted by Kendog on July 08, 2010 at 06:12:50:
Your A came without a generator so the fan assy only had one pulley. You can replace it with one that does have the two pulleys.
