Re: 450 Farmall Hand Crank Start Shaft Replacement
Posted by Wardner on July 08, 2010 at 12:10:32 from (4.154.233.254):
In Reply to: 450 Farmall Hand Crank Start Shaft Replacement posted by Leonj on July 08, 2010 at 11:35:09:
Yes, because the barrel that couples to the crank is usually seized. Then there is the stamped spring retainer which is likely to be seized on the barrel as well as the 1/2" dia pin.
If everything has been gobbed up with grease for the past sixty years, it's not a big deal. Otherwise, you will probably have to remove the bolster. Bear in mind that the job requires one to work on his back with his hands inside the bolster casting. Do you have any 5-6 year olds in the neighborhood who like tractors.
Think about compressing the spring with several tie-wraps.
third party image
I did this partial disassembly to slide the barrel back far enough to install a 2 groove pulley on the crankshaft. This was an old bolster I had to see if it could be done before attempting the same job on my 400.
third party image
As I look at these pictures, I am not even sure that the barrel will come out if the bolster is still attached to the frame rails. I have only removed barrels on separated bolsters. Perhaps you don't need to replace the barrel. You haven't indicated what the problem is.
