Re: hyd oil leaks on 574
Posted by Owen Aaland on July 08, 2010 at 17:13:10 from (65.161.86.20):
In Reply to: hyd oil leaks on 574 posted by mike van on July 08, 2010 at 16:22:20:
I think what you are referring to as a rivet is the top side of the weld on the pivot pin for the shift detent arm. Since it leaks most likely the cause is a crack from the pin flexing. You would be better served by adding weld to strengthen the joint.
