Re: Convert 6v farmall cub to 12v
Posted by Owen Aaland on July 08, 2010 at 17:32:23 from (65.161.86.20):
In Reply to: Convert 6v farmall cub to 12v posted by GeneMO on July 08, 2010 at 10:47:25:
Dalex said: (quoted from post at 20:20:39 07/08/10) You can use an oil pressure switch to turn on the alternater on a mag equiped machine. Then you don't need the diode.
If you have a magneto you don't need a diode anyway. The diode is only to prevent backfeeding the ignition coil so that it shuts off.
With a magneto there is no switch to supply voltage to the alternator to get it to start to charge. By using a two pole, normally open, pressure switch you can apply battery voltage to one side and connect the other to the light/excite terminal terminal on the alternator. That will allow the alternator so start to charge once there is enough oil pressure to close the switch. When the oil pressure drops the switch opens the circuit so the battery doesn't discharge when the engine is not running.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
