Re: *SUPER -M- RUNS AGAIN*
Posted by Owen Aaland on July 08, 2010 at 18:37:14 from (65.161.86.20):
In Reply to: *SUPER -M- RUNS AGAIN* posted by Farmall al on July 07, 2010 at 21:19:46:
mkirsch said: (quoted from post at 14:09:16 07/08/10) Are you saying that you put the resistor BETWEEN the coil and the distributor?
You need to put the resistor between the ignition switch and the coil.
That's why the coil is getting hot.
If you make a drawing of the electrical circuit you can see that it makes no difference in the primary circuit which side of the coil has the resister. The resistance of the coil and the resistance of the resistor are in series so the current draw of the coil will be the same either way. By putting the resistor on the battery side of the coil it is possible to bypass it for more voltage for starting.
