Re: F-20 with Overdrive
Posted by jay Snyder on July 08, 2010 at 18:38:11 from (173.22.177.156):
In Reply to: F-20 with Overdrive posted by Charles B. Jackson on July 08, 2010 at 16:24:26:
Yes it would be worth saving. It probually is a Behlen but there were other manufactors also. They are worth some money. They can be a little tricky sometimes to get the upper shaft off but you will need it. Also yeah it will make your bulls whine a ton when it is opened up and they will move pretty fast. Do not put it on a steel wheel tractor a 15 mph ride on steel would be a killer on lots of stuff your butt to start with and maybe even the operator if you put that lever in gear.
