A properly working regulator will limit system voltage to 14.5 (give a take a few tenths) at all RPM's above about 900 RPM. Also if the VR's cutout relay is stuck closed it will drain the battery flat in less than a day.
Suggest doing this: After shutting down the tractor disconnect the ground cable at the battery. If the battery now stays up after a few days, the problem's definitely the VR. However if the battery still goes flat the battery has worn out and needs to be replaced.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
