Re: Farmall H swinging drawbar and U shaped drawbar questio
Posted by mkirsch on July 09, 2010 at 06:31:45 from (64.80.108.55):
In Reply to: Farmall H swinging drawbar and U shaped drawbar question?? posted by John in CT on July 08, 2010 at 15:26:34:
The main reason for bent drawbars is abuse, overloading, etc.
The horseshoe can get worn thin in the middle where the swinging drawbar roller spends 95% of its time, after 60-70 years of normal use, too.
I wouldn't worry about reinforcing anything unless you plan on intentionally overloading the drawbar.
