12V-6V Resistor Heat
Posted by Bud W on July 09, 2010 at 06:59:34 from (70.242.127.51):
I noticed that the 12 volt to 6 volt resistor on one of my tractors gets too hot to handle within a minute or so of turning the switch on. I checked the voltage and with 12 volts in I seem to have about 4.5 volts out. Looking at the resistor it appears to be in good condition ( no corrosion ). Is this normal. Its hot enough that you cannot hold it in your hand. Thanks
