Re: M thermostat
Posted by janicholson on July 09, 2010 at 13:43:51 from (199.17.6.76):
In Reply to: M thermostat posted by Docs69 on July 09, 2010 at 12:46:30:
They do need a stat. As Clarkbug indicates
I would use a 180 degree stat, and I would also restrict the bypass tube around the stat in the housing to about 3'8" hole. The original bypass is so large that the tractor over cools resulting in poor fuel efficiency. Many never see the Normal zone on the temp gauge unless working a plow or chopper in the summer. Jim
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
