Re: hyd oil leaks on 574
Posted by Owen Aaland on July 09, 2010 at 16:36:47 from (65.161.86.20):
In Reply to: hyd oil leaks on 574 posted by mike van on July 08, 2010 at 16:22:20:
The reason I suggested to reweld the cover where it is leaking is because the crack developed from metal fatigue due to the pin flexing. When it gets bad enough it will break out completely. When that happens you will need to remove the whole cover to make the repair. If you weld it now you could be saving a lot of trouble in the future.
