400 pinion bearing replacement
Posted by Don Hopf on July 09, 2010 at 18:27:20 from (24.214.226.2):
While doing the brakes on the Farmall 400, I found the outside ball bearing cage on the pinion shaft was broken.
Can the pinion shaft be pulled out from the transmission with just the disc brakes removed?
Or will I have to pull out the pinion bearing cage after the the bull gear is dropped?
Thanks
Don
