Re: Charging Problems - SMTA
Posted by sflem849 on July 09, 2010 at 19:13:16 from (69.197.84.192):
In Reply to: Charging Problems - SMTA posted by sflem849 on July 08, 2010 at 18:57:29:
I threw the charger on the battery in the tractor and a known good battery. The tractor started with each. I will leave the "bad" battery out of the tractor and the known good battery in with the cables hooked up. This should double check the battery situation and ensure a VR problem.
Would any problem in the generator cause the battery to discharge?
BTW, the DMM read up to 16.9 at WOT when I tested it tonight. If I had to guess I think I would go with a bad VR.
