Re: Re: F-12 I got to be missing something..............
Posted by oldtractor on June 04, 2000 at 20:08:00 from (63.82.131.149):
In Reply to: Re: F-12 I got to be missing something.............. posted by oldtractor on June 04, 2000 at 19:42:21:
Read your earlier post now I understand . You are out of time, pull the number one plug out, have someone crank the tractor over very slow while you hold your finger over number one plug hole. When you feel the compression pushes on your finger stop, take a flash light shine the light in plug hole, turn again till you see piston come to top and starts back down then stop.Move the motor back to where the piston is top dead center.Now with mag cap off set the segment to number one, at this point the points should be just ready to open. put in the two bolt then you should be in time.
Post A Followup
: Re: Re: Re: F-12 I got to be missing something..............
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
