Posted by joe 1971 on July 10, 2010 at 12:44:53 from (216.51.206.101):
ok. 1486 that all hydraulics get weaker as oil warms. i changed filter,cover seal and gasket. i did the air pressure test in the transmission and found no leaks. i overfilled the trans with 7 gallons of hyd oil. but yet all hydraulics are weak. when at idle i get 800lbs of pressure at the rear outlet but when opened wide open i get around 2200lbs. the 3 point lifts slowly unless i open it up and the steering is hard to turn unless i open it up a little. the light in the dash comes on also. these problems came on all at once so i figured its a suction problem but i cant seem to find any problem. any more ideas? thanks joe
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
