Re: adjusting new brakes on 48 H
Posted by Farmallb on July 10, 2010 at 15:17:15 from (12.74.229.83):
In Reply to: Re: adjusting new brakes on 48 H posted by pete 23 on July 10, 2010 at 15:05:36:
I agree that the lever should run paralell to the bottom of the floorboard, but it dosent It runs up to the bottom of the floorboard. Yes, I can get tension when it is unhooked from the pedal, but the pedal applys way more torque than what I can that, tho I think I have tension by moveing the lever by hand, when I attach it to the pedal, and apply a little tension/push on the pedal, it goes right and all the way down. I suspect that theres something to do with the square headed bolt at the bottom of the cover, tho I dont know what it is. I have I & Ts manual on it, and it says to tighten the bolt all the way tight, and then to loosen it 1/2 to 1 turn till all drag is gone. Whats drag, in something that isnt moveing? the band at the very bottom of the drum isnt moveing to create any drag, so thats got me all lost.
