Re: IH 350 Need Help and INFO (Pics)
Posted by CNKS on July 10, 2010 at 18:00:42 from (216.144.104.128):
In Reply to: IH 350 Need Help and INFO (Pics) posted by Plane Bart on July 10, 2010 at 17:09:03:
Best manuals are at www.binderbooks.com. While waiting on a parts manual, you can find part #'s on www.caseih.com. Engine rebuild kits are available from many sources. This site, also www.batescorp.com. etc. You don't have a fuel filter, unless someone has added one. There is a sediment bowl under the gas tank. Tractor was originally 6 volt positive ground. If someone put an alternator on it, it is 12V neg ground. If a 12V generator has been added it can be either. Wiring diagram is in the operators manual. Serial # is on a tag on the left side of the clutch housing. The number you gave is a prt number off the casting you copied it from. Pictures aren't needed unless you have difficulty explaining some problem.
