Re: IH 350 Need Help and INFO (Pics)
Posted by D Slater on July 10, 2010 at 18:28:52 from (72.65.150.178):
In Reply to: IH 350 Need Help and INFO (Pics) posted by Plane Bart on July 10, 2010 at 17:09:03:
Thats the correct casting # for a 350 utility block. The tractor serial number is stamped in a small plate with 4 rivets mounting it to the right side of clutch housing. Found toward the rear of tractor from the engine oil filter ( not very far) and kind of under the hydraulic tubes.
350 tractors could be 6 or 12 volt positive ground originaly. If it has a battery with it whatever size it is may be what voltage you have.
You need a rebuild kit to fit a 361525R92 carburetor. You can find carburetor and distributor parts for a IH distributor on this site and others or from a dealer.
