Re: H #64 combine won't start when hot
Posted by AJB830 on July 10, 2010 at 19:51:44 from (98.108.21.4):
In Reply to: H #64 combine won't start when hot posted by Prophetstown on July 09, 2010 at 15:35:54:
One other thought on your problem. We had an H that the mag went bad on so I converted it to battery ignition. I used the points in the mag and connected them to an external 6-volt automotive coil and condenser. Worked good for years. Or you could just get a battery ignition unit from another IH tractor and install it.
