Posted by Wardner on July 10, 2010 at 21:35:05 from (4.154.232.8):
In Reply to: Hey Wardner.... posted by Crazy Red Power in SE-WI on July 09, 2010 at 14:18:32:
OK, I am sold. I will have to try some malted frozen confections. I usually go with the quick and easy Ben and Jerry's pint.
Don't know the weight of the soda fountain. I have only handled it with the forklift. I imagine it could weigh 1500 lbs when full of product.
Power steering is in my plans. The Standard Treads use a drag link that is fitted with a hydraulic cylinder and integral spool valve. When the pitman arm moves, the appropriate internal port is opened and extends or retracts the piston. I have this IH system on both my 650 and 660 although they do not interchange. I have been looking for the W400-W450 system. I will probably buy an aftermarket unit. I have seen them priced at $350 and $500. I wonder if they will have enough push/pull to do the job. It is low priority at the moment. The units look easy to attach to any drag link type steering.
As for the wet bar, no thanks. That's a whole basket full of complications I can do without. But the LP tractor fuel could run a grill but that is years away. It would also mean I would be saddled with a payroll. Yuck.
I built a fast hitch for the back end of the tractor. It currently has a large military winch hanging off the back. That will come off and be replaced with something like a hot water tank heated by the engine through a heat exchanger. I have several SS tanks and heat exchangers.
Yes, the tractor will be heavy. It already has a 10 KW generator and a 15 HP air compressor running off the belt pulley. The front hitch parts probably add around 750 lbs.
The log splitter dies are just 2"x 3" chunks of steel cut from the legs of a pallet stacker. The wedge is a spring leaf from a heavy truck. It is way too sharp for a "top die". I insert a piece of 1/4" steel between the wedge and the work. It lasts about 15 bends before it is sheared and replaced.
This post was edited by Wardner at 21:41:30 07/10/10.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
