Re: international 3414 hydraulic pump shaft key sheared
Posted by jay42782 on July 11, 2010 at 05:25:02 from (72.2.175.252):
In Reply to: Re: international 3414 hydraulic pump shaft key sheared posted by Jeff Z. on July 10, 2010 at 21:25:23:
thanks Jeff.sounds like i will be taking the pump to a shop.i will have them run the new key all the way down the shaft as far as they can.
thanks again Jeff as well as others for your help and support!
