Re: H #64 combine won't start when hot
Posted by Janicholson on July 11, 2010 at 06:58:51 from (67.72.98.45):
In Reply to: H #64 combine won't start when hot posted by Prophetstown on July 09, 2010 at 15:35:54:
I would try putting reflective foil insulation between the carb and the block. I would also put foam pipe insulation over the fuel line. If it has spark, and does not run it is either getting too much fuel, or none. Either can be caused by heat.
Jim
