Re: noisey tranmission
Posted by ScottyHOMEy on July 11, 2010 at 11:26:52 from (71.241.221.22):
In Reply to: noisey tranmission posted by edward graves on July 11, 2010 at 08:53:50:
It's gonna be noisier that you're likely accustomed to. It's the nature of straight cut gears. If it varies from gear to gear, you'd also factor in how the tractor was used for most of it's working life. Not at all uncommon to find a gear with the ordinary groan when pulling to get noisy on the coast side of the gear. No harm being done there. If one is exceptionally noisy, you could try replacing it, but how was your (likely used) gear worked, you ma find the sme thing, and would need an experienced eye to determine if the noise is from wear on the driving or driven gear or both.
That said, you can't rule out worn bearings howling either.
As for the pieces you found, hard to say. They sound to thin to be part of a gear tooth, but a good examination of the circumference of each gear would be in order. Could be parts of a worn-through shim, I suppose.
I'd scrape and scoop all the gunk I could out of the case, fill her with diesel or kerosene/diesel and take her for a twenty-minute ride -- don't work her hard with just the kero in there, but work her enough to warm things up and use all your gears, then drain quickly (drive the front wheels of the tractor up onto a couple of short blocks to tilt things back toward the drain). Then refill and see what you've got after that.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
