I looked at the picture i took when i rmoved it -creeper drum still connected to the cover plate pict 6 of 33 and pic 8 of 22 shows shaft but key-way is turned down- i lined up b4 I started
and the drum is going in correctly, on probably 3/4 of the way, but last tightening of cover bolts pushed the bearing out - not all the way out of cover but close, so you can see by picture- drum hub small diameter, goes into sun gear hub.
I just was wondering could i do damge if i kept tightening bolts on cover with a round disk in between to keep the braring from popping off, ie something bigger diam than bearing but fits in creeper drum inside dia.
I can certainly use puller to take it out, it comes out easy with /14 in drive ratchet on puller.
I also made sure key was flat in "way" {key-way} even all the way accross.
I could try to clean it again, and sand it litely clean again and use the pto oil(clean) on it
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
