I like it because it burns cooler and longer . Now the big reason is that todays 87 is a lot lower in octane then what was at the /pump back then . And IF people would look at the Minim fuel requirements you would know more. And if ya think 93 is tomuch for and old tractor it really isn't. Reg gas back in the day was 93 or BETTER and most reg gas was 95 and high test was over 100 , more like 105 and better . Then ya add in a over bore and step head pistons and your comp. ratio is higher throw in a higher compression head . Now as for how hard you work your tractor i do not know but the ones i take care of get worked hard. with running the hightest as they call it today helps to keep them running about 20-30 degrees cooler on the temp gauge. . The hightest of today would make a old 6cylinder cheve ping and knock. Up until gas went over 2.25 a gallon i ran it in the wifes Durango and it would do 18 -18.5 out on the road on the 87 we are lucky to see 16-17 For the Durango only a mile or so a gallon does not pencil out . On the tractors one melted piston and the time to fix the extra expense does.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
