Check the cables after you crank for a while. If they are warm, they are too small. Also check all connections for warmth. Any warm ones need to be cleaned & tightened. There is a timing window on the pump with marks that should line up when on TDC. It has been a while since I timed one so if this is wrong, someone will correct it. Make sure the glow plugs are working. Use them instead of ether.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
