Posted by Janicholson on July 11, 2010 at 20:13:19 from (64.61.211.14):
In Reply to: Re: H liftall posted by Zachary Hoyt on July 11, 2010 at 19:13:41:
If I recall, 6" down from the cap neck will be full. it is very not critical. It is small, and for a loader with single acting cylinders, an auxiliary reservoir is used. T it into the bottom of the Liftall drain, and keep it about the same height, If using 2 way cylinders, the cap on the original reservoir can be non vented. If using a bigger reservoir, that can be vented and higher than the original fill port if the original fill port is capped off W/O vent. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
