well if you pull started it with starting fluid and it ran fine. that kinda tells the story then . plus starting fluid is a no no espesially with glow plugs. were you holding glow plugs and useing starting fluid? thats a good way to screw things up!did you check to see if you had power to the plugs? just because you put new plugs in dont mean anything.they could be toast now though! plus i have never seen 6 burn out at the same time.thats if starting fluid was not used. these engines start easy when everything is in order.is the starter dragging? if you have starter rpm, glow plug heat, and fuel she'll start.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
