Re: Two way lift all
Posted by Wardner on July 12, 2010 at 10:29:27 from (4.154.238.34):
In Reply to: Two way lift all posted by boomer22 on July 12, 2010 at 06:23:46:
That picture bothers me. Could you remove the valve before someone sits on it?
As for open center, you must be able to blow air from the "in" and "out" ports without restriction when the levers are in neutral or "centered".
The valve doesn't appear to have an internal pressure relief circuit. Not necessary as the Liftall has it built in.
