Re: Two way lift all
Posted by mkirsch on July 12, 2010 at 13:38:51 from (64.80.108.55):
In Reply to: Two way lift all posted by boomer22 on July 12, 2010 at 06:23:46:
Get the specs on that valve. It has one too many ports for a two-spool valve.
The extra port at the very bottom of the picture will probably turn out to be the "power beyond" port. It is useful if you wish to connect additional valves or items to the system.
The two larger ports on the top of the valve are the IN and OUT ports.
The four smaller ports grouped in a square on top of the valve are the work ports. Two work ports per lever. These connect to the cylinder(s).
