Re: Hood weather stripping
Posted by Jim Becker on July 12, 2010 at 15:50:56 from (173.57.154.186):
In Reply to: Hood weather stripping posted by Russ from MN on July 12, 2010 at 07:10:25:
The thickness of aything you add is going to make the hood harder to fit. The hood rib may not reach over the seam of the fuel tank. The hood rib may no longer line up with the rib on the grill. If your stripping is very thin, it may not be a problem.
