Re: 706 won't go into high gear
Posted by jdetig1 on July 12, 2010 at 17:08:28 from (204.8.166.234):
In Reply to: 706 won't go into high gear posted by Adam706 on July 12, 2010 at 15:27:12:
my 806 would go into high range but it wasnt easy. i took the dash cover off and adjusted it and put some wd40 on everything. it works a hell of alot better now but you mite have bigger problems than just out of adjustment. it also mite be the range shifting mechanism underneath the range trans cover i have seen those get bent before and make the tractor impossible to shift. i also thought about converting mine to 56 style shift is there a kit for that or how do you go about doing it ?
