I just got the tractor, been tinkering with it when I have time. Steering is very weak and transmission power seems not up to par. I just wondered if having those lines the wrong way could somehow backup some flow or something. I changed the filters, fluid seems clean but I plan to drain it and change it. The flow divider was installed upside down when I checked it and the spring was wrecked. I got a new spring and and put it back together and I thought sure that would have fixed it. Steering is better, before power steering was nonexistant but it steered manually. Hopefully others can chime in if they have knowledge. I was just reading the forums and you had made a lot of hydro posts so I thought you were the guru :)
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
