Re: NO spark
Posted by El Toro on July 13, 2010 at 15:30:04 from (74.103.74.58):
In Reply to: NO spark posted by b4favre on July 13, 2010 at 08:35:25:
Do you have a mag or distributor? If you have a distributor you need to check for battery voltage at your coil with the ignition switch on
and your points open. Should have battery voltage on both small terminals. If there's no voltage on either terminal you need to check your ignition switch for voltage. Trace the wire back from the coil to your ignition switch and see if there's voltage on that terminal. You still need the ignition on. Hal
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
