Re: ih 120 mower
Posted by Wardner on July 13, 2010 at 18:00:22 from (4.154.239.5):
In Reply to: ih 120 mower posted by Jim Dillon on July 13, 2010 at 13:10:38:
I have a 130 mower. By "Pivot Pin", I assume you are referring to the pin that goes through the knife. Mine is 1" dia by 3" long
If you can't find one, you might be able to use an idler shaft used in chain and belt drives.
Brewer Machine and Gear have them in many sizes. The 1" dia comes 2", 3", and 4". I just bought a S0-2 for $10 plus shipping. They are drilled for greasing. The only thing missing is the side cut for the locking bolt. You could give it to a machine shop or grind the notch yourself. They are very hard. I'm using mine as a idler sprocket in a chain drive
Click below for Brewer.
