Re: Duals for Super M
Posted by soybeanjoe on July 14, 2010 at 05:13:04 from (66.213.171.108):
In Reply to: Re: Duals for Super M posted by NDS on July 14, 2010 at 04:39:56:
We ran a SM dualed that way from 1954 till I traded it off in '71 for an 806D. Takes a little work to take the duals on & off. We would take but wheels completely off when removing the dual and put thee inside wheel back on with the dish out to use the tractor for cultivating. At least they never were "froze up" "~)). A handyman jack or portapower & chain is real helpfull when moving them.We also had a tool, real thin piece of metal with tiny rollers that would go in the axle keyway between the axle & wheel key that would alow the wheel to "roll" whn moving. Sometimes worked better than others. I haven't seen that slide since I traded off the SM :~(
