Re: lets try this again.
Posted by glennster on July 14, 2010 at 06:21:04 from (76.224.13.189):
In Reply to: lets try this again. posted by Charles E. McNelly on July 13, 2010 at 15:54:53:
i'm looking at the i+t manual for it, it says the bull gears need to be detached, then the carrier needs to re removed from the the tractor, then remove the spacer and the pin from the outer end of the shaft, then remove the outer bearing retainer. bump outer end of axle shaft. this will dislodge the shaft and inner ball bearing. the outer bearing can now be drifted from the carrier using a long drift against the outer race.
hope that helps.
