Re: H Distributor advance?
Posted by Jim Becker on July 14, 2010 at 07:39:09 from (173.57.154.186):
In Reply to: H Distributor advance? posted by Genos on July 13, 2010 at 21:19:27:
Each distributor has a version and date code stamped into the lower flange of the distributor housing. It may be partly obscured by the mounting clamp (where you rotate it to adjust timing). This will tell you which version you ar looking at, unless somebody has changed internal parts without changing the markings. The code for an H is the letter A. I'd have to go find the code for a 350, which is probably listed in the parts catalog.
