Re: H Distributor advance?
Posted by NDS on July 14, 2010 at 10:04:10 from (205.188.116.73):
In Reply to: H Distributor advance? posted by Genos on July 13, 2010 at 21:19:27:
It will work advance may be different BUT if you go to parts book they give generic distibutor (353870R91) for all applications on both H and 300. Some say you must have exact curve and that may be so if you are after that last 1/2 HP but many of these old tractor did hard work for years with magnetos and magneto does not have centrifical advance.
