Posted by M Diesel on July 14, 2010 at 10:36:55 from (12.24.61.12):
In Reply to: Leaking MD fuel line posted by Janicholson on July 14, 2010 at 07:36:12:
Janicholson said: (quoted from post at 07:36:12 07/14/10) Clean it well with brake clean spray, then use good light and watch where it begins leaking. A careful analysis might find a crack that will not be repairable, but it could be a flange or seat that has a scratch that can be polished out. A good diesel shop (or someone willing to look at the part using possible teflon lined stainless steel brake line as a substitute) might work. Salvage yards are the only other alternative. Jim
Really does sounds like a crack. There is no pressure on that fitting. I will say the filter isn't especially needed either. It is just there as a precaution to stop crud introduced into the line from getting into the primary pump.
Salvage yards are a good option, like steelwheelranch.
The entire unit can be replaced with standard plumbing if you want. I have used a standard hose barb and rubber line at that point. I can't remember if it is 3/8 or 5/16.
It is possible the leak may be sealed with fuel lube. You need to be careful with that stuff around injection pumps, it should not be gooped on.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
