Maybe you just need to polarize the generator. It amounts to momentarily connecting bat. on battery or other battery location to gen on generator. This sets up the magnetic field so the generator can charge. There is a write up under frequently asked questions that will give you more details. This is a simple but necessary procedure. On a cub this assumes you have the Battery+ as ground and the negative connected to the load. If you are wired the other way then change it so that when you are looking at schematics or reading about cubs you will be set up as original. The 48 cub was positive ground. Your question about what is a good ground. I agree with the other answers but it is as simple as a good ground looks like the battery ground to the system. I.e. there is no resistance between the connected ground and the battery terminal that is grounded.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
