Re: M clutch fibers around hyd pump
Posted by charlie M on July 15, 2010 at 06:32:40 from (74.41.94.226):
In Reply to: M clutch fibers around hyd pump posted by ChrisMO on July 15, 2010 at 05:01:19:
You can remove the clutch on an M without splitting the tractor. Half the work is removing the belly pump so if you already have that out you may want to remove the clutch and have a look at it.
