Posted by caterpillar guy on July 16, 2010 at 04:19:59 from (66.188.53.165):
In Reply to: 766 brakes posted by kevin peel on July 15, 2010 at 16:49:27:
Take the one that is acting up off and clean the rust and gunk out and it will probably work fine. Also check the lining thickness while your in there. Also check for leaks around the piston. If the pedals are not even in travel, you will need to loosen the bolt on the pedal linkage and adjust them so they are even also.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
