Re: IH 5 FT sickle mower
Posted by Jim Becker on July 16, 2010 at 07:45:29 from (173.57.154.186):
In Reply to: IH 5 FT sickle mower posted by MNGB on July 14, 2010 at 18:04:58:
The 16-B was essentially the same, different drawbar to fit the different tractor. The left side of the drawbar did not reach to the left side of the tractor. It was designed to bolt to the mounting pads on the axle extrensions to each side of the differential. I think it used all 4 bolt holes.
The tool box on this one was added by someone after it was in use.
