Re: h p.t.to hard to engauge
Posted by pete 23 on July 16, 2010 at 10:20:52 from (173.87.9.157):
In Reply to: h p.t.to hard to engauge posted by sunaewayha on July 16, 2010 at 09:44:29:
If it is the later extended housing style pto, you can take the plug out of the spring detent from the outside, maybe just relax some of the tension on the detent. Older, original have detent inside. Just did this to an M as someone had apparently replaced the spring with a much heavier one. Sometimes they start jumping out of gear and people will washer up the detent or some other sort of quick fix.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
