Re: 460D serial number
Posted by Andrew Z on July 16, 2010 at 12:25:31 from (64.252.148.52):
In Reply to: Re: 460D serial number posted by tntleake on July 16, 2010 at 12:07:43:
They put larger/stronger bearings in the rear. The rear that the 460 had was a good but was originally designed to handle the Farmall H (28hp), as years went buy they beefed up the rearends from the super h (34hp), to 300/350 (37hp). However the 6 cylinder high rpm engine the 460 (45 hp) got just took a toll on them. The 560 had the same issue.
Andrew
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
