throttle won't stay on 1466
Posted by Larry B 1486 on July 16, 2010 at 16:42:42 from (67.142.161.30):
The last 1466 I bought last spring am having trouble with the throttle not staying. Is there a friction disc that holds the throttle or what do you tighten up to keep in where you put it. It keeps backing off and you have to hold it going thru the field. You run it up to 2000 rpm's and in 30 seconds it will be down to 1500 unles you hold it.
