Re: Super H Alternator
Posted by janicholson on July 17, 2010 at 13:34:21 from (199.17.6.76):
In Reply to: Super H Alternator posted by Bill Porter on July 17, 2010 at 13:11:57:
The Hitachi from a mid 80s Nissan Pu is a great choice. It is small enough to allow some adjustment.
A Delco10SI will fit, but touch both the hood and block, making belt adjustment less desirable.
The Hitachi has 3 terminals, the big stud goes to the Amp meter (load side)
the S terminal goes directly to the stud, and the L terminal goes to a diode, idiot light, or 10 ohm 10 watt resistor), then to the ignition switch. The diode should be 3 amp, 50 PIV with the band marking on the end attached to the L terminal. These three options keep the tractor from running with the key off. Jim
